has the component cable come loose for anyone? mine isn’t exactly loose in that it falls out but every so often the color on the screen will go bad on mine and i have to twist the cable for the color to be corrected. it’s very flaky. and yes… the cable is in all the way.
Sounds like a dirty connector.
