Live Hub to AV Receiver
Hey guys,
I’ve been using this forum alot to set up my last Live Hub, but I’ve moved out and am buying a new one, so thanks!
I was wondering, is it possible to share the wireless connection and wired connection between the Live Hub? I purchased an AV Receiver that has Airplay and I want to have my Live Hub on wireless, then run a crossover cable from the Hub to the AV Receiver.
Can this be done?
Nope. Every device on the network has to have a unique DHCP address to be able to access the network.
Even if I gave them all static IP’s?
as soon as you plug an active network cable into the hub, the wireless interface will be disabled.  You cannot use them both simultaneously.
