Ive kept my live hub firmware at 3.00.28 because i had so many problems with updating them.So what i would like to no now,is there an update that doesn’t have problems or should i just keep it at this one?.i don’t want to have to role back again.thanks
All Firmware’s have “issues” whether these issues will affect you ,depends on your setup.
Read the Forum for bug reports concerning latest firmware, and from there, make an informed decision and what course of action you would like to take.
I’m not telling you what to do, but if you’re are happy with 3.00.28 and have no problems with it, and you don’t want to have to roll back firmware … then i know what i would do.
Some people here advise “Make sure you’re running the Latest Firmware”
I don’t subscribe to that “advice”
P.S. I’ve rolled back due to HDMI issues (which ive never had in the past) and now HDMI is all good 3.05.10
thanks for your advice.ive updated to the latest firmware,after reading what others have said&so far it seems to be working ok.i updated on the 10/02/2013.as said before,thanks.
