I’m considering in purchasing a WD TV live hub.
Question:
Can I stream music from the WD hub to my Logitech SqueezeBox radio?
Ian
Question:
Ian
If the Logitech SqueezeBox radio supports the option to access a shared folder or media server it should work.
Not sure about the shared folder, need to check this out.
The squeezebox looks for the Logitech “Squeezebox” Media Server, anybody know if this can be installed on th WD HUB.
Ian
Ian_D wrote:> Not sure about the shared folder, need to check this out.
Ian
You can’t install anything on the hub but the the hub itself is a Media Server. Turn on the DLNA Media Server on the hub and check if your Squezebox can see the hub. If it can, that’s it but if not, it won’t work.
