Had the issue where the WD TV live hub kept rebooting when using the virgin superhub.
So carried out the know sort of fix, of increasing the UPnP to 1440, and this has resolved the random reboots.
However, when I turn on the WD hub,
the WD LED Light Control comes on (I have the setting set to always off)
I see WD loading screen
3. The WD hub turns itself off
It then loads
The media library recompiles itself
If I am not connected to the virgin superhub network, the WD hub loads without issue.
I have tried turning of UPnP but the same reboot steps occured above.
I have the lastest version of the hub, 3.05.10
Anyone got any ideas what I need to adjust / turn off on the superhub to stop this occuring?
Thanks in advance.
Also, couldn’t see any errors in the logs in advance setting screen of the virgin superhub
