Okay so my setup is the below
Server --cat6–> Gigabit Ethernet Router --cat6–> Live Duo, I am currently getting 30MB/s transfering files
When I change the setup to look like this I still get 30MB/s transfer speeds both devices are set to 1000M Full Duplex
Server --cat6–> Live Duo
I dont see why this should not be running at a faster speed
Please can someone help
Thanks in advance
30MB write is about right. Reads should be substantially faster.
You say “both devices are set to 1000/Full”
How did you do that on the duo?
Well, Live Duo is on Auto-Neg, But advertised as 1000M Full when plugged into a 1gbps Switch, My PC Is hard set to 1000M Full.
Thank you for the information, I was not aware of this
Thanks for the information,
Is this speed a limitation on the hard drives inside or a limitation with the WDLD Nas itself… Basically would purchasing a different NAS give me better performance increase?
Regards,
Sure… More money will get you better performance, usually…
