Hi all,
the tab Link Speed contains only two options
Auto and 100 missing 1000
Is there another option about?
thank’s
Hi all,
thank’s
hello there,
Is your unit connected to a gigabit router ? If your router is gigabit and the option is not there even if you have a gigabit connection, try to do a system restore on the unit.
This link might help you out:
http://wdc.custhelp.com/app/answers/detail/a_id/10433
Hope this helps you out.
hi,
solved…
thank’s for all
