When I checked myCloudmirror today, the led for HD1 was showing red and there was a caution message on accessing settings. I have run diagnostics and scanned eack disk which are set as a JBOD configuration. There are no reported errors and system is reported OK, temperature etc. fine.
I have just rebooted (lengthy) and the message now says healthy. Could you please advise if I should be concerned and suggest possible cause.
I note from the logs that there were a large number of FAILS of authentification e.g.
2016 Mar 30 10:09:11
SAMBA
CIFS: Authentication for user [myemail@blahblah] has FAILED.
I am that user and this log message was produced presumably before the lengthy reboot.
I have also recently had messages to the effect the WD was closing down. When checked the system appeared to be OK.
On coming onto the forum I note that this all seemed to coincide with an auto-update yesterday. Coincidence or something to worry about?
John B
