I would like to know if one (if any) of the 2 to 4 bay USB enclosures will work with the SMP? I was looking @ this one:
will any of these work if plugged directly into a WDTV unit?
thx
Scott
thx
Scott
The SMP only supports single USB drives, if you want to use a multiple drives enclosure you may try with a NAS.
I was just curious if u setup the HD’s right to make them look like ONE drive it would work? OR if that is something u can only do with BIOS setup for a computer and not the SMP I totally understand…which I assume is the case
