JoeySmyth,
Thanks for advice. With big variety of Android product, it’s difficult to choose the correct one.
Does TANIX T5 Firmware included in COOLEME package or separate?
Thanks again.
nope, separate … personally, i don’t think it’s necessary (unless you want Root Access)
Is there any essential difference between COOLEME® MB1, MB2, and MB3? Or for the streaming performance and quality it does not matter?
JoeySmyth,
In the list of specifications for COOLEME MB1:
“Supports*.mkv,.wmv,.mpeg,.dat,.avi,.iso,mp4,.rm and.jpg file formats”
I did not find .vob format.
Is that really so or they simply skip it?
T95X has this .vob container.
Thank you.
Yes, it plays *.vob fine (tested with Android MX Player and LibreELEC [Kodi]
Main difference between MB1 and MB2, MB3
MB1 = Amlogic S905X
MB2, MB3 = Amlogic S912
that’s all the advice i can give. i have the MB1 and it works fine for me …
JoeySmyth
I could not make the right decision.
Thank you for your time and valuable advices.
