Hey, guys!
I’ve got the my book live 2 tb connected to my 1 Gbit router Zyxel Keenetic Giga. Everything works good, except the problem of connection speed. MBL doesn’t connect at 1 gbit, only at 100 mbit. At first I was thinking, that there is some problem with my router, but it works perfect with my PC at 1 gbit. The cable is ok, cat.5e and i’ve tested it with pc and router. Can someone help me with this problem?
There’s two possibilities:
1- Autonegotiation incompatibility between the MBL and router (rare.)
2- Bad interface on the MBL.
my netgear 3700 is same to you,it is so bad,:womansad:
how do i know what speed the mybook is connected with??
cant see it in my router, and the router does not have any leds on back.
can i see it somewhere else?
Login via SSH and do
ifconfig
I think ifconfig doesn’t show nic speed. Try this instead: ethtool eth0
SSH ?
edit:
Ok, ive searched and i downloaded “PUTTY”.
How do i connect? can i do it over internet? or do i have to be at the same network?
it was connected with 1 gbit. thanks for the help
