I have some issues in iTunes server. So, I searched the knowlege base and in “iTunes server and how it works on a WD network drive”. I found the instruction set. but it does not match . I installed also WD Link in Windows.
To enable or disable the iTunes Server Service:
- Ensure that the device is powered on and connected to the network.
- Click Start.
- Click All Programs (on Windows XP this will just be Programs ).
- Click WD Link.
- Launch the WD Link application.
- Click on the drive you wish to set up the iTune library for in the Devices Found list.
- Click on Configure.
- The login page appears. Type in the administrator name and password.
- On the iTunes Server Service page, click Enable next to iTunes Service to enable it. Or, deselect the option to disable it.
- Specify how often iTunes can scan the device for new music files.
- Click Submit.
on step 8, it takes me to the dashbord without typing in admin paaswd and that may be due to I did not set it. The, I needed to go to Settings->Media->iTunes. I enabled it there but I don’t have the choice of you mentioned in !0 and also no submit.
Is there a new version of this Dashborad?
Thanks,
Sankar
