ITunes problem Since upgrading to window10, my ITunes cannot see the My Cloud drive, also I keep getting an error when my WC control panel tries to scan the content.
This drive has worked fine for almost a year and since upgrading to windows 10 my smart TV’s and my other devises can’t find the drive I have updated the firmware, done a factory reset. but still have massive problems.
This is what I did, In windows credentials from the settings menu I added a windows credential using the IP address, and then the name of the pc with log in details. But during my messing about I also mounted the drive and deleted my C:drive Itunes folder. then re scanned my music once I could set the parameters to the right folder.
Its working but I have to admit I am not sure which one solved the problem. WD still working on a reply.
