I spent a week trying to get the Live TV to connect to my network. This is what i discovered.
It doesn’t work. This device would cause havoc with my network cause the NAS drive to hang. I spent many hours trying to figure this out.
Solution. Return to Best Buy and replace it with a panasonic DBT220 Network Blu-ray player with streaming media and NAS support.
This cost me 10.00 more, works great, and i got a blu-ray to boot. The only complaints that i have with the panasonic is if you have alot of small video files in a folder you can’t do a slideshow so you have to select the next video and press play. It’s a little bit of a pain. I will try creating a playlist to see if that works. Also it does not play Itunes music.
For me I wanted to stream Video and photos from my NAS so this works great. U-tube works well also. I have not tried the other streaming services yet.
Good luck all with your live tv. I had none
If you are having problems with Live TV working with your network I’d say dump it and try something else.
