Updated WDTV Live to latest firmware and the WDTV no longer see’s the Seagate drive, it says no USB device is attached.
I am using a 2TB Seagate drive, model SRD00F2.
The drive is working as it is recognised by my computer.
It was working on the last firmware, I have tried using another cable, power cycling the unit and reseting factory defauts and using another WDTV Device all to no avail…
A few other people seem to be having thw same issue, please can this be investigated…
Some more info, its worth pointing out that this is someone else’s media setup…
This is a new drive for them. I have tried reverting to previous firmware versions on the wdtv and the drive still isint recognised. I will raise a support call with Seagate.
I am experiencing the same issue with a portable Seagate Backup Plus 2TB drive. I have tried partitioning the drive in both MBR and GPT, no dice. Very disappointing as I was looking forward to having access to a larger capacity drive than my existing 500Gb Transcend unit (fortunately, that one works fine).
