We have used our MyBookLive successfully for months as a network storage for our company documents. Recently we have started having connection issues. Works fine one day and not the next. When we loose the connection to our MyBookLive I am able to see it in the Network connections and successfully ping. In the beginning it was as simple as an unplug to reboot the drive and all was good again. Last week I was able to get it up after unplugging the power, network and using the reset button. This week, nothing seems to work. Still visible on the Network but not accessible. Here are the error messages I receive when I attempt to go to mybooklive/ui/ in my browser
Warning : require(cake/basics.php) [function.require]: failed to open stream: No such file or directory in /var/www/UI/index.php on line 52
Fatal error : require() [function.require]: Failed opening required ‘cake/basics.php’ (include_path=‘.:/var/www/Admin/webapp/lib/pear/includes:/var/www/UI:/var/www/UI/app/’) in /var/www/UI/index.php on line 52
Following the link I get
Warning (2): Invalid argument supplied for foreach() [CORE/cake/libs/configure.php, line 1122]
Code | Context
$type = "core"
$path = "libs"
$paths = array()
$paths = array();
foreach ($path as $key => $value) {
App::__paths() - CORE/cake/libs/configure.php, line 1122
App::import() - CORE/cake/libs/configure.php, line 847
App::import() - CORE/cake/libs/configure.php, line 809
require - CORE/cake/dispatcher.php, line 31
include - CORE/cake/bootstrap.php, line 51
require - APP/webroot/index.php, line 81
[main] - CORE/index.php, line 61
Fatal error : Class ‘Router’ not found in /var/www/UI/cake/dispatcher.php on line 282
The following Windows error also started coming up when I attempt to access via the mapped network drive
"An error occurred while reconnecting V: to \MyBookLive\****
Microsoft Windows Network: The local device name is already in use.
This connection has not been restored"
