I have been trying to update my firmware to 3.0.14 am having problems.
Tried tyo auto download option several times keep getting an issue saying my Network is at fault; I can assure you my network is perfect fine; tried it about 10 times over 48 hour period
TRied Manual option; I downloaded the firmware placed onto a USB at root no folders etc. Inserted USB after bootup device recognoized USB I selected Cancel to question re: Synching. But it did not pick up the firmware.
The WD hib is on vesion 3.0.8; my question is I can access the WD box via ethernet; can I not just place the files into a directory and re-boot the device rather than having to do use a USB ?
thanks in advance.
Darragh.
