Hi there,
I hope someone here can let me know if it is possible to install the Applications that originally came with the PASSPORT external (USB) Drive when the drive is still in use as a backup.
The reason why I deleted all the Applications from the Drive was because I had so much problems with them that in the end I felt it is easier to delete them and just use the Drive as a straightforward backup drive for Copy To or Copy and Paste function. ( I had posted one of the problems on here back in July last year and that was not resolved even after contacting Support directly that in the end I reformatted the whole Drive and start afresh without installing the Applications)
Now that I have so much data saved as backup in the drive, including some sensitive data, I felt the need to have the Drive password protected and wondered if I could install the SECURITY application from the software that came with it (I have all the programs that initially came with the drive saved). My question is:
Do I need to delete all the backup data to install the Applications or can I just install it while the existing data are in the drive and without corrupting or destroying the backup data ?
Any clarifications or suggestions will be greatly appreciated.
Many thanks in advanced.
