I have installed the latest software WD My Book World Edition for Windows. I can start the program and see the buttons but there’s no text in the buttons.
The OS is Windows 7 Ultimate (Dutch) 64 bits.
The drive is connected to my network and accessible.
If someone knew anything abouth this, help is welcome.
I managed to get everything installed because I just went on to the CD and ran various (I didn’t document them…) setups manually. But it bugged me that the install wouldn’t work in the normal way, so I pursued the issue.
I called support and both level 1 and level 2 support said it was a faulty CD.
So I downloaded the install image from the download site and had the same problem.
So next, I shared my PC CD drive and ran install from a laptop, and no problem there.
It’s definitely something on the PC, but I have no idea what it is.
I’m just posting this in hopes that it can narrow down the possibilities for other more expert people.
You’re not alone. Windows 7 64 bit. First run it got to the point where it’s supposed to say what my drive is, and what the next step is, but it couldn’t find my drive. So I tried to run install again. Now the CD drive just clicks when I click the screen where it lists the install options 1/2/3. Going to try downloading the CD to burn. Was really excited. Not impressed at all so far.
attempted reinstall from new burnt CD. All the text boxes are blank. Maybe I missed this a few times in the install guides, I was attempting to connect wireless. I physically plugged my laptop into the router and can now see the drive. Went through some of the install, but now it times out on the configure screen after I setup a password for the admin.
So if you can’t see the text in the boxes, click the top box. That should install a link on the desktop and run it for you. Apparently make sure you’re physically connected to the router to see the drive. That’s as far as I got
