Installation problem with MyBook Essential 1TB
I have tried to install WD SmartWare to a Windows XP v2002 computer. Installaton seemed to run fine until the status field showed “starting services”. Then after 20second thinking, it said: “rolling back action” and “setup wizard ended prematurely”. (I started installation from WD SmartWare library, using the (x86) setup file.
Does this problem has anything to do with:
a) my computer is partitioned in 2 sections
b) my computer may not have flash plugin
c) my computer runs an older XP version and has no internet connection (no updates since it was first set up - i use this for file storage only…)
d) other?
I appreciate any useful inputs.
Thanks, A.
It’s probably missing tthe drivers it needs. Windows probably needs to be updated. Try downloading SP3 on another PC http://www.microsoft.com/downloads/en/details.aspx?FamilyID=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en This is a stand alone version ignore the thing about updating one computer. See fi that helps. If this is a hacked version it may detect it.
Joe
Joe, thanks. Indeed, i had to install 3.1 version of Windows Installer. Thanx!
Another question you may know the answer to. Can i simply run backup of 2 different PCs to the same MyBook? Do i need to watch out for anything special in doing so (e.g. specifying to different back-up sources…)?
Thx, A.
