I have a hard disk capacity of two Terra … The USB port crashed … The piece fell into the hard.
Is there a possibility to fix this problem?
Can I recover the Hard again until it works properly?
You should contact Data Recovery companies to see, how they can help you to recover files from the drive.
I would suggest you to connect the drive to another system and check whether it is working or not.
