Hello. If anyone could help with this I would appreciate it. I have had a hard time setting up my new 3TB My Cloud, network connectivity and first wave of saving files to it was no problem. But I have a different login for my Dashboard than I do for the My Cloud drive on my laptop and I am not sure why. Then I go to the Safepoint to create one and it wants a Share Login and I have absolutely no idea what that could be. But it seems not to be any of my other logins. How do I get or create a login for that? Thanks.
Well, if I am following the steps correctly, it appears I am trying to create a safepoint on my laptop. Then I have options for various drives (ADMIN$, C$, D$, etc.) and at the bottom of that list is an option to select “Users”. When I do that, I enter the username and password for the main User on My Cloud and nothing happens. Should I do something else or enter the username for a Share instead?
I assume that if I have all of my actual files backed up on both the My Cloud and an external hard drive, that maybe a Safepoint isn’t necessary? Thanks.
