Impossible to join AD with Firmware 2.11.140
After update Firmware to 2.11.140 I can’t join to my Active Directory.
Before the update I was working fine with my Active Directory but after this update when I logging in the device I could see that I was out of the AD then I tried again with the same configuration but always have the same error: … Check that the name of the domine is the same that AD. Sorry, translation from spanish.
Any help?
Have you tried resetting the unit and trying to set that again. since you did an update, the unit might still have previews firmware information.
