Ok so basically it constantly says my disk is at 100% on task manager, i removed windows search like some threads told me i need help
Try googling “100% disk:site tenforums.com.”
Try this if you haven’t already. In Task Manager, click the Processes tab (It should default to this tab). Now click the title ‘Disk’ at the top of the disk usage column. This will sort the processes in descending order of disk use and help you identify the culprit.
