I accedently erase my drive with wd smatware .. pls help
hello
i accedently erase my hdd (my passport) 1 T
from  setting > drive set up > erase drive
how can i retrieve my data again??
can i retrieve it or not ?
i use 3 data recovery software & the data still exist but how can i recover paths of the directory , directory structure , and the clusters for each specific file ??
i recover large files with unknown data only
wats the solution ???
Try reinstalling the wd smartware software to see if the settings return. Here is a link for the download.
http://www.wdc.com/wdproducts/wdsmartwareupdate/step2.asp?id=wdfMP_Essential&os=WIN
i mean that i erase my data with the wd smartware not erase the wd smartware itself
i accedently done that by the wd smartware from erase my drive boton in the drive set up
do u understand me ???
i need my data back
any one can help me ???
which program may be useful ??
i use 3 programs but they restore large file with unknown format
how can i found the directory structure & the original location of the files ??
