hello
i accedently erace my hdd (my passport) 1 T
from setting > drive set up > erace drive
how can i retrieve my data again??
can i retrieve it or not ?
hello
You’ll need a data recovery software, try TestDisk, Recuva or PhotoRec first as they’re free. If those can’t help you then contact a recovery company.
i try it but found large files without any extention
i need directory structure & the original location of the files
how can i get it ??
you will need to research online for a software like that, and it won’t be free. just make sure that you don’t rewrite to the drive before doing a recovery. you could also try a partition recovery software. that might do it.
