Hub painfully slow after firmware upgrade
Hi
1st post so go easy on me.
I have the hub a few months and everything was fine until I updated the latest firmware.
It is constantly freezing and it is very slow to react to to any button being pressed on the remote.
Even when I press and hold the power button it takes about a minute to power off.
It is driving me nuts.
Any ideas?
Anyone before I throw this thing out the window?
Have you tried resetting the unit. Press the bottom paperclip button for about 1 second and then release with the unit fully booted up.
I downgraded the firmware and its working ok now.
It must be a firmware issue. Surely when a new firmware update becomes available it should improve things not make them useless.
It may be a firmware issue that does not explain why it does not happen to other users (like me).
Did you try the reset before you downgraded.
No I didnt try the reset before the firmware.
I will update firmware again and see if its ok and will reset it if its not going smoothly.
Thanks for your help.
update on this.
Its not working again.
When I start it up it is not going past the ‘loading mochi’ screen,
