Just got my Hub so bear with me(previously had a 1st gen)
I have attached to it a 1TB drive with 3 folders Movies TV_Shows Music, hub sees the folders and the content in them.
However I have created 2 folders on the Hub in the root also called Movies TV_Shows, however the Hub does Not see these folders or their contents, but if I drag the content to the root of the Hub’s drive it will then see the content.
Am I missing something here? Whats up with this?
I’d like to move my content from my 1 TB to the internal but if It wont see the folders…
The folders are in the Root of the Hub’s hard drive, I networked to the Hub’s hard drive, I created 2 folder in the root, right where I see the .wdtv folder etc ( I deleted the SampleFolder that was there) TV and Movies folder , I put movie.avi in the folders , then I filter by folder I see my 1TBHD and LIVEHubFolder , I look in the LiveHubfolder but it says no media found.
When I put the avi in the root, same level as the folders I can then see the avi but no folders are shown.
If the folder doesn’t have any videos, that folder will not appear in the videos because the hub doesn’t show folders which don’t contain relevant files but you can still copy to that folder. When you use the copy command in the hub and select internal storage and WDTVLiveHub, that folders you created will appear so you can copy to that folder.
