I guess my question is more concerned with my TV channel guide. If I am watching a show and then decide to surf the channel guide, it remains on the screen if I do not select a new channel. What do I need to press to remove the guide?
Have not used the Sling Player service, but have you tried pressing the back button on the remote control?
I can’t remember exactly but try the blue button on the remote and if that does not work try the other colored buttons.
