On my livebook duo 2 disk - raid 0.
I had to reset the disk box configuration but after this I lost all my data.
Is there a way to recover them ?
tmc
tmc
Hi, you can try using a data recovery program for NAS, but I’m not sure that it will work.
i tryed to remove the 2 disk and plug them in my windows system then i tryed a few raid recovery programs, Sometime it took 24 hours to scan the disks… but nothing good to recover… For example I only got some parts of corrupted avi.
Quite weird to me because I haven’t written on the raid after the WD raid system factory reset.
Well juste never reset to not loose data… I know it now !
Nowadays so many data recovery companies provides data recovery software. You should compare the rate and choose a best one according to your requirements.
You can check the a good data recovery software at: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
