Well I guess I bricked my MBL DUO (white light) and I wasn’t even doing anything to it, except one possibility. I was working on my Debian desktop via SSH and adding a 2nd HDD, and modified my fstab and rebooted. No human never makes mistakes, and I wonder now if I picked the wrong SSH shortcut and modified the MBL’s fstab?
However I got here this is what I have: I have removed one of the MBL’s HDDs and physically mounted in my Debian Wheezy desktop. I run fstab -l and I get this:
[quote]WARNING: GPT (GUID Partition Table) detected on ‘/dev/sdb’! The util fdisk doesn’t support GPT. Use GNU Parted.
Disk /dev/sdb: 4000.8 GB, 4000787030016 bytes
255 heads, 63 sectors/track, 486401 cylinders, total 7814037168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/sdb1 1 4294967295 2147483647+ ee GPT
Partition 1 does not start on physical sector boundary.[/quote]
Now I’m sure my data is still happily alive on the HDD but the MBL bricked (no SSH, no web access) and I didn’t delete any files, so I see no reason I can’t recover my data and move it to a different MBL. (I have 5 of them.) EXCEPT… I am obviously going to have to install some package on my Wheezy desktop that will allow it to access the MBL drive. Then all I have to do is map another MBL into the desktop and use one of the many methods of moving the data over to a good MBL.
So here is the question I will appreciate answered. What Wheezy package(s) must I install on my Debian desktop so that it can access the MBL HDD’s different partitions or whatever is preventing me from logically mounting it?
Once I get it mounted you can see it will be a piece of cake to copy the data over to another MBL.
How do I read the MBL drive when mounted inside my Debian Wheezy desktop?
