Hi all,
I am trying to map a network share into a drive (letter) using WD Discovery.
Adding the public share is no issue at all, but adding my personal share is not successful so far.
A colleague told me that he only succeeded once using the identical login details from his PC on the Cloud (so the account on the cloud needed to be setup identical to the PC) but is that the only option?
When entering the credentials (login and pw from the cloud) during the process, it keeps returning as if “not approved”.
Anybody any idea how to map when the user is setup differently than the pc?
Regards,
I already got the public to work (this manual refers to the public also) and that is the easy part (took only a minute), my problem is the “user” one (so in this example “Jan”).
I would like to create a drive for that section also, but it does not allow me to do so.
I am sure I am doing something wrong, but I cannot figure out what that is.
