yeeho
1
I have a USB to Serial (CP210x), but i can’t get the driver work with my cloud usb and doing e.g. echo hello >/dev/ttyS0
it there a build in Rx TX in my cloud
Connect Arduino to my cloud
sorry to ask to many questions, i just want a serial port connection
Thank you
cat0w
2
Here is a link to the User Manual and it should answer all three of your questions.
http://www.wdc.com/wdproducts/library/UM/ENG/4779-705103.pdf
You may want to check out the Knowledge Base too. Click on that at the top right of the page.
yeeho
3
checked and read, nothing was found
@yehho, have you manage to connect arduino to mycloud? I am curently facing that problem with no sucess…
