If you want a solution for How to Extract Attachments from EML files with an instant and error-free solution without installing any third application to process them you can read this discussion here I have suggested the best solution for all users should try it.
here I have the best and most professional solution for all technical and non-technical uses they should try the Softaken EML Attachment Extractor Tool, which is a user-friendly solution. This solution makes extracting attachments from emails containing EML files easy. Users can easily open these attachments after they have been deleted. This tool lets you delete CC, BCC, topic lines, etc. to extract attachments from EML file instant solution in bulk. It works with various EML email clients, including Windows Live Mail, Thunderbird, and eM Client. This application provides instant results to extract all PDF, Doc, ZIP, RAR, JPG, PNG, and GIF. If you want to learn its features, try its free trial version after installation. This software can work with Windows 11,10, 8.1, 7, XP, and Vista operating systems.
