Hi, i have a wireless modem, i bought a Tenda wireless N Access Point to transform a wireless network to a wired network.
Everything works fine, i can connect to the internet, but i can’t see My BookLive Duo on the network, what i have to do?
Simone
Since you are on a different router, did you tried resetting the drive? If not, please try that.
Hi ERmorel, how could i reset drive? I have to download some tools from wd site?
No, Just press and hold the reset button on the back of the unit for 4 seconds and the unit will reset.
