How Do I Write Zeros (Low Level Format) My Drive?
Running a WD 750GB Black drive on a Dell laptop, Windows 7.
I want to do a clean install but first would prefer to do a low level format and reset the drive to a factory fresh state.
Previously when I’ve tried this, whatever WD software I attempted to use just would not work and Iwas forced to use a third party disc wipe program, (Kill Disk).  I’d prefer to stick with WD.  Thank you.
Take a look at this KB article regarding Low Level Format:
http://wdc.custhelp.com/app/answers/detail/a_id/1211/
Hi John,
I’ve read that article.  Problem is, the utility that WD offers doesn’t seem to work, at least for me.  I’ve tried using the Data Lifeguard but for whatever reason I haven’t been able to get the DOS version to work.
Can you be more specific?
What part of the process is not working?
First, I downloaded Data Lifeguard Diagnostic for DOS to my desktop:  http://support.wdc.com/product/download.asp?groupid=703&sid=2&lang=en
Then as per the instructions I extracted the file and copied it to a floppy.  Set the BIOS to boot off the floppy I receive a message that the program I’m trying to run is incompatable with the OS, which is Windows 7.
I’m probably doing something wrong but I haven’t been able to this figure out.
The application is running on DOS therefore the OS does not come into the picture yet.
You can try creating a CD instead of the floppy disk and retry.
When I boot off the floppy, (which has been formatted as instructed), the screen shows:
Starting
A:>
I don’t know what to do at that point.
I would create a CD, but when I download and extract the file it is a .exe file.  Don’t I need an ISO to create the disc?
