How can I adjust sound volume on a WDTV media player?
I just bought the WDTV live media player to play movie videos ( format :  .flv)  on my CRT TV set .
How can I adjust the sound volume ? There is no button on the WDTV remote control for sound volume . Adjusting the
volume control on the TV set has no effect at all !
Please help .
put the sound output into a stereo amp and speakers
If adjusting your TV’s volume has no affect, then where is the sound coming from?   Can’t be from the TV…  (Or the TV’s controls are messed up…)
  fender62 &  TonyPh12345:
I apologized for   not express myself clearly …  I forgot to mention that the audio  output  was connect to an earphone .  It works O.K. when connected to the CRT TV  .
If connected to an earphone, I would expect the sound volume control must come from the WDTV media player .  Currently, I just hear the sound through the earphone  at a  fixed level  . I used the remote control trying to configure the sound volume but could not locate any appropriate options provided therein  .
I tried the DRC ( Dynamic Range Control ) option but nothing changed .   Please help.  Thanks
The WD has no amplification built into it at all headphones will not work. It’s known as a line out output
Maybe a volume control adaptor for your earphones will work ?
JoeySmyth:
You are absolutely correct !   I  used a headphone with a volume control ( in-line,   similar to your photo )  instead of an earphone , and it really worked . !!   Thank you so much for your great tip !
It’s interesting to note that a DVD player does have volume control buttons on its remote control  but not our  WDTV Live media player !!    :cry:
My gratitude to TonyPh12345, tm224 and fender62 for your quick  responses and constructive suggestions .
 Best regards,
