Help with wireless adapter
I am driving myself mad trying to find a wireless adapter that will work. The problem is that most of the listings do not give the revision / version number and this seems to be a big issue.
Can someone post a link to a specic item (Amazon in the UK if possible) that they know does work. I would be eternally grateful.
Hi
I have been trying to setup a wireless network all this afternoon, the WDTV Live is not recognising the USB Wireless adapter.
I purchased the Belkin Surf & Share Wireles Adapter &7D2101 v1 as per your compatible list & am having trouble.
I have read through most of the threads & can not see any help anywhere.
Can you please lend some assistance.
Make sure you’re running the latest firmware.   That adapter was added in 1.05.
Thank you, a bit of mucking around but all is working well.  :slight_smile:
I bought this router and all is working well. http://www.amazon.co.uk/gp/product/B002RCKDEC/ref=oss_product. even though it is not on the tested list
hi there
  • pls check key codes [wpa/aes/wpa2] - all unts must serve the same key code
  • in other words - make some check with different key codes options
  • nevertheless - this is worh to mention that there is nothning more stable then a cable [rj45]
kind regards
pawson
