Hi everyone, I’m looping a short video from a USB stick and each time the loop starts back a “Subtitle OFF / No audio channel” warning displays on the top left corner of the video. Is there a way to disabable that and the spinning loading arrow that is visible for a few seconds even when the loop has already started playing? Thank your suggestions.
Hi, nope :confounded:, as far as I know there is not option to disable it.
Has been requested for ages but WD doesn’t care.
Try using the Auto Play function (if it works). I believe that this does not display the annoying box.
