Help with TV and My essentials book
Hi! When I plug my hard drive into my tv it says there are no files on the hard drive when there are any help on fixing this would be great Thanks in advance.
It probably needs to be formated FAT32. Try posting in the TV section you may get  faster help.
Joe
it says there are no files or you don’t see the files?
Is the drive recognized at all?
Check the user manual for the TV to see what is the file system that the TV supports
Joe
 there is no TV section for External Drives , he is in the right forum
