Need help with mapping shares on the MBL Duo 6tb.
I have a static IP at home. At present I can access the shares within my home network and also thru wd2go web-site. What I would like to do it, connect directly to my shares outside of my home network without going thru the wd2go site.
Since I have a static IP, I am guessing this should be possible - just don’t know how to go about doing it.
I should add that at the moment, the NAS is not set-up using a static IP with a port forwarding done on the router. I can access the Dashboard using the IP and the port 1024 within my own network.
Any help with this is greatly appreciated.
