Got this from an old computer at a garage sale, 160gb, largest drive i have ever held.
Squeaks when moved, reads but doesn’t get recognized in the bios.
Can you help me with this? Really want to use this!
Is your drive a WD1600AAJS, and is this your PCB?
http://community.wdc.com/t5/forums/replypage/board-id/caviar/message-id/6700
If so, then AIUI your drive is a member of the “Tornado” family. This family is afflicted with an MCU fault that mimicks head or media problems.
Alternatively, it could be that your motherboard cannot support a SATA speed of 3Gbps, in which case you could try installing the drive’s OPT1 jumper.
Jumper Settings for WD SATA and EIDE Hard Drives:
http://www.wdc.com/wdproducts/library/other/2579-001037.pdf
