I just started ripping my BluRay to be played on my WD TV Live Streaming.
Tools I have are HandBrake and DVDFab Blu-Ray ripper.
I can create m2ts and mkv files that work just fine on my PC with VLC.
I can play the BluRay disks just fine on my PS3.
My hardware is a bit of a kludge. I have a older DTS & Dolby Digital 5.1 receiver that takes optical in and SD video. These are the first iterations of DTS and Dolby Digital and does not support the new BluRay HD audio. To get around buying a pricey new surround setup I have added two items. A 4 to 1 HDMI switcher and a HDMI Optical break out box. It works great with DirectTV in HD, PS3 including BluRay movies, XBOX, and most things with WD TV Live STreaming.
I have been playing DVD ISOs with network shared from my Win 7 PC without too much issue that I cannot figure out a way to get around if there is too much disk protection by ripping out the main movie. (LAN connection not WIFI)
My problem now lies in getting 1080p movies to play audio with the WDTV Live Streaming. I think the issue is my older receiver does not like the HD Audio as I hear nothing from my 1080p MKS and m2ts rips of my BluRay movies. I have tried several setting in Handbrake and DVDfab without success in being able to hear audio.
I have found a couple of anime movies on the web in 1080p that plays just fine. Audio and all. So I don’t think WDTV is to blame at all. VLC says MPEG AAC mp4a and AC3 stereo audio streams on one and MPEG AAC Audio mp4a on the other. . This leaves me with trying to find the magic AUDIO format to convert to for my setup.
I have no interest in saving disk space by compressing the video. That is not my problem.
I have tried the following in DVDFab.
m2ts.default with Audio set to 448 kbps bitrate and 5.1 multichannel and stereo
checked the Remove HD Audio checkbox.
m2ts.ac3.normal
m2ts.passthrough
Handbrake I have not tried yet as I need to rip to a interim video format.
Has anyone a solution with Handbrake, DVDFab, or other free program that can correct the AUDIO for older DD DTS receivers with limited bandwidth?
I would like 5.1 if possible. Best quality would be my older DTS supported format . But at this point I think I would be happy with anything even stereo.
Scott
