I’m trying to set up a media server. My file is displaying at 16:9 widescreen. However when i play the video the the WD live device it is still putting black bars on the top and bottom. Below is the mediainfo result on the file. Any suggestions would be helpful. Thanks
General
CompleteName : I:\DVD_VIDEO\6th Day Magicdvd.avi
Format : AVI
Format/Info : Audio Video Interleave
Format_Profile : OpenDML
FileSize/String : 1.16 GiB
Duration/String : 2h 3mn
OverallBitRate/String : 1344 Kbps
Encoded_Application : Magic0515
Video
ID/String : 0
Format : MPEG-4 Visual
Format_Profile : Advanced Simple@L4
Format_Settings_BVOP/String : No
Format_Settings_QPel/String : No
Format_Settings_GMC/String : warppoint0
Format_Settings_Matrix/String : Default (H.263)
CodecID : XVID
CodecID/Hint : XviD
BitRate/String : 201 Kbps
Width/String : 640 pixel3
Height/String : 360 pixel3
DisplayAspectRatio/String : 16:9
FrameRate/String : 29.970 fps3
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bit3
ScanType/String : Progressive
Compression_Mode/String : Lossy
Bits-(Pixel*Frame) : 0.029
StreamSize/String : 177 MiB (15%)
Encoded_Library/String : Magic0432
Audio
ID/String : 1
Format : MPEG Audio
Format_Version : Version 1
Format_Profile : Layer 3
Format_Settings_Mode : Joint stereo
Format_Settings_ModeExtension : MS Stereo
CodecID : 55
CodecID/Hint : MP3
Duration/String : 15mn 12s
BitRate_Mode/String : CBR
BitRate/String : 128 Kbps
Channel(s)/String : 2 channel2
SamplingRate/String : 44.1 KHz
StreamSize/String : 13.9 MiB (1%)
Alignment/String : Alignment_Aligned
Interleave_Duration/String : 34 ms (1.02 video frames1)
Encoded_Library/String : LAME
”äØ / q>.
²W!KTæ
