Help with connection to pc
Hi. today i buy a wdtvlivehub then i found with the problematic connection to my pc “with the ethernet connection to my router” i already install “WD Discovery Tool” and make the connection when i run the program find the WDTVLIVEHUB but when i want “Map Network Drive” showme this window:
BEFORE I can connect mine to the PC, using cat5 to network card, I have to make sure the Hub’s network settings are set to AUTOMATIC. Then Windowz 7 will see it. I don’t use the WD Discovery Tool at all.
Is 190.160.221.234 a valid ip address for private addresses? I could be wrong but I though you can only use 10, 172, 192 as the first ocet.
Can you map the drive from you pc?
