[updated] Now, samba share doesn’t work…dlna appears to be working…I didn’t do anything other then reading the logs from ssh session.
[original]
Hello, I have a WD MyCloud 4TB. I have configured it and enabled ssh when I was in US. Then I moved it from US to China. Now, when I turn it on, the web admin doesn’t work. I can still see the share folders from my windows. The dlna doesn’t work.
When I ssh in, I was able to “curl taobao.com” and it returns the html content. When I do “curl http://localhost”, it would hang…I have to break.
Now, what else must I do to have my admin back? Should I reset the device? Is it the china firewall the preventing the device from working? I guess I don’t need the cloud aspect if that’s the issue. Is there any command/log I can check to see what’s wrong?
here’s the apache2 log:
[Sat Dec 06 03:10:44.113454 2014] [auth_digest:notice] [pid 4577] AH01757: generating secret for digest authentication …
[Sat Dec 06 03:10:45.012327 2014] [mpm_prefork:notice] [pid 4577] AH00163: Apache/2.4.9 (Debian) OpenSSL/1.0.1g configured – resuming normal operations
[Sat Dec 06 03:10:45.012889 2014] [core:notice] [pid 4577] AH00094: Command line: ‘/usr/sbin/apache2’
[Sat Dec 06 03:11:12.010658 2014] [mpm_prefork:notice] [pid 4577] AH00171: Graceful restart requested, doing restart
[Sat Dec 06 03:11:12.605337 2014] [auth_digest:notice] [pid 4577] AH01757: generating secret for digest authentication …
[Sat Dec 06 03:11:12.926185 2014] [mpm_prefork:notice] [pid 4577] AH00163: Apache/2.4.9 (Debian) OpenSSL/1.0.1g configured – resuming normal operations
[Sat Dec 06 03:11:12.926235 2014] [core:notice] [pid 4577] AH00094: Command line: ‘/usr/sbin/apache2’
[Sat Dec 06 03:13:52.912247 2014] [core:notice] [pid 4577] AH00052: child pid 7666 exit signal Bus error (7)
[Sat Dec 06 03:14:46.869892 2014] [core:error] [pid 4577] AH00546: no record of generation 0 of exiting child 7666
[Sat Dec 06 03:14:46.870038 2014] [core:notice] [pid 4577] AH00052: child pid 6064 exit signal Bus error (7)
[Sat Dec 06 03:14:46.870140 2014] [core:notice] [pid 4577] AH00052: child pid 6065 exit signal Bus error (7)
[Sat Dec 06 03:14:46.870196 2014] [core:notice] [pid 4577] AH00052: child pid 7683 exit signal Bus error (7)
[Sat Dec 06 03:14:46.870228 2014] [core:error] [pid 4577] AH00546: no record of generation 0 of exiting child 7683
[Sat Dec 06 03:14:48.879726 2014] [core:notice] [pid 4577] AH00052: child pid 7783 exit signal Bus error (7)
[Sat Dec 06 03:14:49.884852 2014] [core:notice] [pid 4577] AH00052: child pid 7812 exit signal Bus error (7)
[Sat Dec 06 03:14:50.889831 2014] [core:notice] [pid 4577] AH00052: child pid 7840 exit signal Bus error (7)
[Sat Dec 06 03:14:51.894820 2014] [core:notice] [pid 4577] AH00052: child pid 7847 exit signal Bus error (7)
[Sat Dec 06 03:14:52.899768 2014] [core:notice] [pid 4577] AH00052: child pid 7850 exit signal Bus error (7)
[Sat Dec 06 03:14:53.904845 2014] [core:notice] [pid 4577] AH00052: child pid 7851 exit signal Bus error (7)
