Decided to clean up our cloud storage today and have discovered it has moved all the .jpgs from the folders they were originally in (for example Customer1 New Build) to the root (I think) of the cloud drive.
When I use the app I can see the photos under the “photos” tab, but on pc it only shows the the folders, unless I type in a search for *.jpg. This is currently utterly useless as the photos are linked to many different projects, is there any way I can change the view back to how it was (open folder X, see the relevant photos) quickly or do I have to loose many hours of work manually looking at each picture and moving it to the correct folder.
N.B. the only thing left in the now empty folders that contained the jpegs is the thumbs file.
Thank you in advance, I really can’t drink any more coffee today!
