Help please
I made some modification to the settings.json file of my transmission install.
I am a total a newb, please help out…
WDMyCloud:~# /etc/init.d/transmission-daemon start
[…] Starting bittorrent daemon: transmission-daemon[22:53:53.454] JSON parse failed in /var/lib/transmission-daemon/info/settings.json at **bleep** 1219: SPECIAL_EXPECTED – remaining text “/etc/init.d/tran”
(warning).
Current state of my settings.json:
“alt-speed-down”: 3000,
“alt-speed-enabled”: true,
“alt-speed-time-begin”: 540,
“alt-speed-time-day”: 127,
“alt-speed-time-enabled”: true,
“alt-speed-time-end”: 1350,
“alt-speed-up”: 1500,
“bind-address-ipv4”: “0.0.0.0”,
“bind-address-ipv6”: “::”,
“blocklist-enabled”: false,
“blocklist-url”: " http://www.example.com/blocklist",
“cache-size-mb”: 4,
“dht-enabled”: true,
“download-dir”: “/DataVolume/shares/Public/Transmission”,
“download-limit”: 100,
“download-limit-enabled”: 0,
“download-queue-enabled”: true,
“download-queue-size”: 5,
“encryption”: 1,
“idle-seeding-limit”: 30,
“idle-seeding-limit-enabled”: false,
"incomplete-dir": "/root/Downloads"
“incomplete-dir-enabled”: false,
“lpd-enabled”: false,
“max-peers-global”: 200,
“message-level”: 2,
“peer-congestion-algorithm”: “”,
“peer-id-ttl-hours”: 6,
“peer-limit-global”: 200,
“peer-limit-per-torrent”: 50,
“peer-port”: 51413,
“peer-port-random-high”: 65535,
“peer-port-random-low”: 49152,
“peer-port-random-on-start”: false,
“peer-socket-tos”: “default”,
“pex-enabled”: true, /etc/init.d/transmission-daemon start “port-forwarding-enabled”: false,
“preallocation”: 1,
“prefetch-enabled”: 1,
“preallocation”: 1,
“queue-stalled-enabled”: true,
“queue-stalled-minutes”: 30,
“ratio-limit”: 2,
“ratio-limit-enabled”: false,
“rename-partial-files”: true,
“rpc-authentication-required”: false,
“rpc-bind-address”: “0.0.0.0”,
“rpc-enabled”: true,
“rpc-password”: “{41807483133e17b6a3f52595cde51747a689d663ML67owt9”,
“rpc-port”: 9091,
“rpc-url”: “/transmission/”,
“rpc-username”: “transmission”,
“rpc-whitelist”: “127.0.0.1”,
“rpc-whitelist-enabled”: false,
“scrape-paused-torrents-enabled”: true,
“script-torrent-done-enabled”: false,
“script-torrent-done-filename”: “”,
“seed-queue-enabled”: false,
“seed-queue-size”: 10,
“speed-limit-down”: 100,
“speed-limit-down-enabled”: false,
“speed-limit-up”: 100,
“speed-limit-up-enabled”: false,
“start-added-torrents”: true,
“trash-original-torrent-files”: false,
“umask”: 18,
“upload-limit”: 100,
“upload-limit-enabled”: 0,
“upload-slots-per-torrent”: 14,
“utp-enabled”: true
here’s mine …
“alt-speed-down”: 50,
“alt-speed-enabled”: false,
“alt-speed-time-enabled”: false,
“alt-speed-time-end”: 1020,
“alt-speed-up”: 50,
“cache-size-mb”: 4,
“download-dir”: “/shares/video/torrentz/”,
“encryption”: 1,
“incomplete-dir”: “/root/Downloads”,
“message-level”: 2,
“peer-limit-global”: 700,
“peer-limit-per-torrent”: 100,
“peer-port”: 51413,
“preallocation”: 1,
“ratio-limit”: 2,
“rpc-password”: “{4034f8d0323fcd01a7fb66b4261cfedd7651dcaeT5u.S4xq”,
“rpc-port”: 9091,
“speed-limit-down”: 10,
“speed-limit-up”: 10,
“speed-limit-up-enabled”: true,
“umask”: 18,
“utp-enabled”: true
Thank you, this is great help!
