had a power outage and when power came back, the drives where no longer accesible. The unit is visible on network, but filesttructure seems to have gone. I have two disk set up in raid set-up. Is there any way to access the drives and try to recover the data?
—Maximum Capacity (Spanning) combines all the drives in a system into one big volume so that they act like one giant drive. •
Maximum Protection (RAID 1)—Sets the system to data protection mode (also known as mirrored mode) and the capacity is divided in half. Half of the capacity is used to store your data and half is used for a duplicate copy. If one drive goes down your data is protected because it is duplicated.
That is the problem. The unit shows up on network but not accesible through UI or fileshare. It shows 0% usage and temperature unknown. I should be receiving a new unit under warranty but would not like to lose my data. So need some help in going through that process once new unit arrives.
