3x HDD’s Externals, in Spanned Mode.
( 2 & 3; In MediaSonic enclosure, eSata Cable with PCI-Express )
I want to format my PC with clean install,
the problem is that all these RAID’s are
SoftWare & the HDD’s are DYNAMIC.
Sorry for my lack of knowledge, but will i be able to use this RAID’s normally after the format?
Or i need to break all RAID’s, then make it again with the newly installed windows? & HOW?!
PS: all these HDD’s are WD Green, but diffrent in sizes.
Support for your RAID array can be obtained from one of several sources:
If you are setting up a hardware array it is best to contact the manufacturer of your RAID controller or motherboard manufacturer.
If you are setting up a software array you can contact the publisher of your RAID software.
The publisher of your Operating System (OS) (Usually Apple, or Microsoft) can provide support for the use of a hardware or software RAID configuration within that OS.
